No TOS Application
odd42
No TOS Application
Post by odd42 »
Hello
for testing i installed a 500 GB HDD und some TOS apllications ( clam AV, Docker )
After changing Test HDD to regular NAS HDD (seagate Ironwolf 4TB) all the TOS applications are gone.
So i upgrade to TOS 4.1.30 but nothing changed.
Today i do a reinstallation with TOS 4.2.06 but the application come not back.
I go back to TOS 4.1.32 but no luck.
Please help
TMS
Re: No TOS Application
Post by TMS »
odd42 wrote: 21 Nov 2020, 01:23 After changing Test HDD to regular NAS HDD (seagate Ironwolf 4TB) all the TOS applications are gone.
Please make sure whether tnas is connected to the Internet and whether the network settings are correct?
odd42
Post by odd42 »
hello,
thanks for reply.
NAS was connected to internet but ip was was in access restrictet ip-range.
so i changed the ip adress for F2-210.
Now looks fine. :D
thank you
TPiatek360T
Post by TPiatek360T »
I'm having a similar problem. After I cleared up a situation where the NAS wasn't recognizing the two surviving disks from a RAID5 array as... well, having anything useful on them and being addressable, I have the RAID repaired, and things are normal... except, no apps.
Like, the system knows they WERE there, but they don't have icons, if I click them, it says they need to be updated, and if I agree, it goes to an app page that's blank and I can't do anything on.
For reference:
2020-11-22 19_25_51-Desktop - TOS and 5 more pages - Personal - Microsoft_ Edge_LI.jpg
2020-11-22 19_30_11-Desktop - TOS and 5 more pages - Personal - Microsoft​ Edge.jpg
2020-11-22 19_27_49-Desktop - TOS and 5 more pages - Personal - Microsoft​ Edge.jpg
2020-11-22 19_26_09-Desktop - TOS and 5 more pages - Personal - Microsoft​ Edge.jpg
I'm still backing up the NAS to make sure this doesn't happen again (i.e. next time I can just wipe everything and start over if necessary), but I've tried everything except turning it off and on again. Network access doesn't seem to be a problem, but I wouldn't know how to diagnose it if it were. It downloaded and installed the TOS on its own last night...
by odd42 » 21 Nov 2020, 01:23
Hello
You mentioned that you have changed the HDD. So is the 500 GB HDD inserted still?
Anubis101
Post by Anubis101 »
just bought f4-422 installed a hdd set it up but no apps my f4-210 works fine could you help or where can i get the plex tpk and ill put on my self :D
TMS
Post by TMS »
Please make sure whether tnas is connected to the Internet,the plex app can be downloaded in the application center.
Anubis101
Post by Anubis101 »
it is connected to internet but no apps
TMS
Post by TMS »
Hi, try modify your DNS to 8.8.8.8(TOS control panel>Network config ).
Anubis101
Post by Anubis101 »
ive tried that and its still the same
Return to “Others”
