[SOLVED] D5-300C with Linux usb resets under heavy io
e6SBylizVXn4
Post by e6SBylizVXn4 »
TL;DR this device (D5-300C) bought Feb 2024 from Amazon needs decent power on the USB port it is attached to to work correctly. After attaching this device to a powered USBC 10gbps hub (this one specifically: https://www.amazon.co.uk/dp/B0C39RX3R9? ... ct_details) I have flawless operation without resets using Debian 12, UAS with no quirks, and smart pass through
Posting here so people can shortcut the journey I went on to solve this
Nice enclosure on the whole, except for one issue around powering the chipset that controls the USB to SATA bridge
ID 174c:3074 ASMedia Technology Inc. ASM1074 SuperSpeed hub
ID 174c:55aa ASMedia Technology Inc. ASM1051E SATA 6Gb/s bridge, ASM1053E SATA 6Gb/s bridge, ASM1153 SATA 3Gb/s bridge, ASM1153E SATA 6Gb/s bridge
It seems like the chipset itself is powered by the USB port its attached to, and only the hard disks are powered by the provided adapter.
Which means if you attach this to a Raspberry Pi or some mini pc (N100 etc) solution, you can get errors like the following under heavy io (particularly between disks in the enclosure)
kernel: scsi host0: uas_eh_device_reset_handler start
kernel: usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
or
[59450.518157] DMAR: DRHD: handling fault status reg 2
[59450.518182] DMAR: [DMA Read NO_PASID] Request device [00:14.0] fault addr 0xfffff000 [fault reason 0x06] PTE Read access is not set
[59481.301844] sd 3:0:0:0: [sdd] tag#6 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD OUT
[59481.301863] sd 3:0:0:0: [sdd] tag#6 CDB: Write(16) 8a 00 00 00 00 00 72 b8 6a 00 00 00 02 00 00 00
[59486.393672] xhci_hcd 0000:00:14.0: xHCI host not responding to stop endpoint command
[59486.393695] xhci_hcd 0000:00:14.0: xHCI host controller not responding, assume dead
[59486.393794] xhci_hcd 0000:00:14.0: HC died; cleaning up
[59486.393819] usb 3-3: USB disconnect, device number 2
[59486.393982] ------------[ cut here ]------------
[59486.393986] WARNING: CPU: 0 PID: 14 at drivers/iommu/dma-iommu.c:1038 iommu_dma_unmap_page+0x79/0x90
or
[ 3443.131328] usb 2-1.1.3: cmd cmplt err -71
[ 3443.131392] usb 2-1.1.4: cmd cmplt err -71
[ 3443.190576] usb 2-1: USB disconnect, device number 2
[ 3443.190592] usb 2-1.1: USB disconnect, device number 3
[ 3443.190598] usb 2-1.1.1: USB disconnect, device number 4
[ 3443.190906] sd 2:0:0:1: [sdc] tag#18 uas_zap_pending 0 uas-tag 1 inflight: CMD
[ 3443.190917] sd 2:0:0:1: [sdc] tag#18 CDB: Read(16) 88 00 00 00 00 00 8d ea d4 00 00 00 02 00 00 00
[ 3443.190932] sd 2:0:0:1: [sdc] tag#0 uas_zap_pending 0 uas-tag 2 inflight: CMD
or
[208212.269219] hub 2-1.1:1.0: hub_ext_port_status failed (err = -110)
[208213.293075] usb 2-1.1-port3: cannot reset (err = -110)
[208214.317073] usb 2-1.1-port3: cannot reset (err = -110)
[208215.341112] usb 2-1.1-port3: cannot reset (err = -110)
[208216.364903] usb 2-1.1-port3: cannot reset (err = -110)
[208217.389047] usb 2-1.1-port3: cannot reset (err = -110)
[208217.389084] usb 2-1.1-port3: Cannot enable. Maybe the USB cable is bad?
Then after reading posts like these
https://forums.raspberrypi.com/viewtopic.php?t=245931
https://forums.raspberrypi.com/viewtopic.php?t=353854
I've put a power USB hub between my mini pc and the enclosure and I have had no resets since, with Debian 12 kernel 6.1 UAS and no quirks, with smart pass through. Everything working as expected
Hope this helps someone!
e6SBylizVXn4
Re: [SOLVED] D5-300C with Linux usb resets under heavy io
https://forums.raspberrypi.com/viewtopi ... 0#p2172556 this post in particular inspired trying a powered USB hub
e6SBylizVXn4
I should add, other symptoms were my PC not seeing the device at all and random USB disconnects on PC boot
e6SBylizVXn4
I should add, this solves the problem for me using the standard provided TerraMaster usb c to usb a cable that came with the device, I've not tried it with other cables
Carrot8697
Post by Carrot8697 »
I agree with this hypothesis. I have a D6 320 that has the same issues without using a hub on Debian (the host PC is a Gigabyte Brix mini PC). When hooked up to my Mac, no issues - all well and good. I'm using the stock TM USB-C cable in both cases.
Using a generic AliExpress PD USB-C cable also removes issues when connecting to the Brix but yields abysmal transfer rates.
Seems the Brix isn't supplying enough power to the ASMedia chip over USB-C. Using a powered hub seems like the best option.
Carrot8697
Additional finding to whoever sees this in the future: using a 3.x USB-A to C cable also fixes the issue (speeds went from 20 M/s to 175 M/s and everything is solid/stable). That said, the powered hub would yield ~200+ M/s.
HappyBreadDuck
Germany
Post by HappyBreadDuck »
I've had similar issues with my D6-320 if it was connected to the USBC port of my laptop using the provided USBC-C cable.
Connecting the USBC-C cable to an C-A adapter and then connecting this to the USB 3.1 A port on my laptop solved this issue. I think transfer speeds went down using this option - still have to test that.
Connecting the USBC-C cable to a powered hub and this hub to my laptop solved the issues as well. This had no change in transfer speeds.
HappyBreadDuck
Germany
I've since then bought the suggested powered USB hub.
TLDR: The hub made things worse. I dont think my D6-320 is at fault, more likely the usb controller in my notebook (linux host).
I ran some more tests, both with both my current drives (containing one failed drive) and later with new drives.
My errors did only appear during heavy IO while my failing drive was still included in the pool. My best guess is: ZFS read data from one or more "data" drives and one or two parity drives. (Raid6) One of them was the failing one, so zfs tried to correct the data on this drive using the parity information. This resulted in even more IO, because zfs was now reading from some drives and writing to the failing one. If this failing drive times out, the kernel is forced to reset the entire usb connection.
Maybe somewhere along the way the usb controller in my notebook (linux host) or the usb controller in the D6-320 had some latency problems as well.
Adding the powered usb hub in between caused these problems to appear more often than without the hub. To me, this suggests that this hub is built cheap and cannot handle anything near 10 Gigabit.
Since these issues even appeared (once) while benchmarking 6 new drives, the usb controller in my notebook might also not be able to handle this reliably.
Return to “USB Series”
