D5-300 not responding even with HDDs out
fred
Post by fred »
I'm using D5-300 since many years with a RAID configuration with satisfaction. I have 7 D5-300, good stuff.
One day, I couldn't reach one of them, with a RAW problem appearing in windows when checking windows disk manager.
I tried to reset the config on the D5-300 by removing all discs but it is not recognized by windows anymore, nor with TM raid manager.
I tried to connect the disk on other PC but same result. Now I can't even see a RAW because it seems that the D5-300 is not even recognized with USB. When I plug it, nothing happens on windows... Since I have many D5-300, I tried by changing cable or charger, but it doesn't work...
What should I do?
Thanks for your help
Re: D5-300 not responding even with HDDs out
Hi! Please refer to the article for troubleshooting.
viewtopic.php?f=67&t=2398&p=12970#p12970
fred
Post by fred »
Thanks for your reply, but i can't run check disk since the D5-300 is not recongnized anymore by windows. It became RAW format at the beginning but now when I start it, the 5 HDD lights are green and ON and then after a few seconds, the HDD lights are off and nothing happens on windows.
I tried with another USB-C cable: it doesn't work...
Seems like there's an USB problem?
Should I contact the warranty or is there another step that I have to follow to fix that?
Hi! Please contact our tech team for warranty service.
