D2-310 Fan wiring
Re: D2-310 Fan wiring
Specification of the fan on D2-310:
Dimension:80*80*25mm
Supply Voltage:DC 12V
The spacing of 4-pin terminal or 3-pin terminal: 2.5mm
Please find the specification of the pin:
travail99
Post by travail99 »
Thank you very much for this.
Tricky
Post by Tricky »
TMSupport wrote: 21 Dec 2020, 17:32 Specification of the fan on D2-310:
If the tach feedback is not connected can I ask if the fan speed is controlled by varying the voltage?
{L_BUTTON_AT}Tricky
Yes, it is controlled by voltage.
Tricky
Post by Tricky »
TMroy wrote: 21 Dec 2020, 22:33 [at=Tricky post_id=6349 time=1608557024 user_id=140][/at]
Thank you. :)
Return to “USB Series”
