RAID Manager Pro
Geldartm
RAID Manager Pro
Post by Geldartm »
I i have just got this i have set op raid and also changed the password to get into the software, now when i try and log in it will not recognize it, i know it is correct as saved it in the browser. after creating it, any help would be great
Thanks Martin
Re: RAID Manager Pro
If you forget your password, uninstall the software and install again.
Geldartm
Re: RAID Manager Pro (SORTED)
Post by Geldartm »
Got it sorted thanks for anyone else this is how
Just a note for those who may have this same problem on a Windows based system. You can default the username/password by:
1. Stop the service "hptsvr"
2. Rename or delete "hptuser.dat" from the Windows directory
3. Start the service back up
Login using username "RAID" and password "hpt". You will be prompted to change the password, and it WILL allow you to put "hpt" right back in as the password, should you so choose.
Return to “Thunderbolt 3 Series”
