Thunderbolt 3 RAID driver installation guide (Mac Os versions prior to 11.4)
FAQs and instructions only for Thunderbolt series raid storage
Instruction
To use a hardware RAID, you need to install the RAID controller driver on your computer, otherwise, the computer will not be able to recognize and manage your RAID.
Applicable Models:
D4 Thunderbolt 3, D5 Thunderbolt 3, D8 Thunderbolt 3, D16 Thunderbolt 3
Step 1: Install the driver
1.1. Download the driver. https://download2.terra-master.com/T3_R ... 211116.zip
1.2. Find the downloaded driver file, then double-click the software package to start the installation program, and click the [Continue] button.
1.3. Mac OS will prompt you to install the driver, click the [Install] button.
1.4. The system will prompt to enter the administrator username and password, and then click [Software Installation]
1.5. Pay attention to the [Security and Privacy] pop-up window prompt, click [Open Security Preferences] and click Allow to run [Enable System Extensions], please do not ignore.
Reminder: Click [Open Security Preferences] to pop up [Security and Privacy Window]
1.6. After making sure that ‘App Store and Approved Developers’ is selected, click on ‘Allow’:
1.7. You will receive a pop-up window. Click the [Restart] button to execute the system expansion cache reconstruction. After the execution is complete, click the [Restart] button.
Step 2: Check whether the driver is installed successfully
2.1. Please keep the Thunderbolt 3 device turned on and connected to the computer, log in to the Mac OS as a system administrator [Go to → Utilities] and open the [Terminal] window.
2.2. Enter the following command and press Enter: sudo su
2.3. After completion, enter the Mac OS password in the Password field, and then press Enter (note that the password will not be displayed).
2.4. Enter the following command and press Enter: kextstat | grep high*
2.5. Please confirm that the version is 4.23.6.
2.6. Congratulations on the successful installation of the driver and the Thunderbolt3 device can be used.
swldstn
Re: Thunderbolt 3 RAID driver installation guide (Mac Os versions prior to 11.4)
Post by swldstn »
What if you have gone through the install but your kextstat shows you an older version of the driver? (4.13.?)
How do you fix this? Is there a way to force the old driver to uninstall?
TMnorah
Post by TMnorah »
Hi!
It does not need to be updated to the latest driver, the 4.13.x version of the driver can be used normally.
Corrected the wrong version number.
swldstn
Post by swldstn »
So the original post with driver version 4.23.1 was incorrect and the proper one is 4.13.2 ? Please confirm. Thank you.
Yes, version 4.13.2 is suitable for MAC OS 11.4 or earlier.
JoseLuis
Post by JoseLuis »
I have followed all the steps correctly, but the D8 does not recognize the disks.
There was a time when it did recognize them, I do not remember exactly which version of macOS Big Sur but when I installed 11.6 it did not recognize them again. So I had to downgrade to a version below 11.4
I attach the screenshots.
Stan
Spain
Post by Stan »
Hello.
What should users do in 2024 with a newer operating system? I have Sonoma 14.3, and I followed the procedure described in the first message, but the terminal shows the driver version 4.22.1. Do you have anything more recent for modern macOS versions?
Stan wrote: 18 Jul 2024, 10:46 Hello.
Depending on your macOS version, the content of this post is not appropriate.
Here are the instructions for the RAID driver for your macOS 14.3.
viewtopic.php?t=2462
viewtopic.php?t=2463
Stan
Spain
Post by Stan »
TMzethar wrote: 20 Jul 2024, 01:29 Depending on your macOS version, the content of this post is not appropriate.
I have an Apple T2 chip. I followed the instructions for this chip as stated in your guide (second link), but after checking with the command "kextstat | grep high*", it shows version 4.22.1. Now, I can't access the administration via the browser at http://localhost:7402/ (it was working yesterday). Could you please advise what might be the issue?
