Mac stops detecting HDD in Single Mode/Thunderbolt 3 DAS
pratapj
Post by pratapj »
Hi there,
I recently purchased a Thunderbolt 3 Pro-Grade 2-Bay RAID 0/1/JBOD/SINGLE (Diskless). I am using it in Single Disk mode with 2 HDDs - EXOS 12TB and WD 6TB Black.
First, I had problems with an EXOS 12TB hard disk. The drive was detected by my M1 Mac Mini when I first plugged it in. I already had data on it. After using it for a few days, my Mac displayed the message "The disk you attached was not readable by this computer.", So I initialised the hard disk and copied all my data back onto it. The drive worked fine for a while, but suddenly stopped being detected by the Mac, with the same error message. I understand that the EXOS 12TB hard disk is not on the Thunderbolt 3 recommended list.
But today, my Mac stopped detecting the WD 6TB Black, which I had in the second bay. The Mac displayed the same error message, "The disk you attached was not readable by this computer." I have critical data in the 6TB which is not backed up.
And as per the compatibility matrix, the WD Black 6 TB (WD6003FZBX) is supported. Mine is a WD6002FZWX. Could that be the reason for incompatibility? is there a way I can get to my data? I plan on testing the drive with another external hard disk enclosure which I need to borrow from a friend. Meanwhile, please tell me how I can troubleshoot and avoid these errors, and possibly get to my data.
Thank you
Re: Mac stops detecting HDD in Single Mode/Thunderbolt 3 DAS
This problem is due to an error in the file system of the disk partition.
Please pay attention to:
1.recommended format for large-capacity hard disk:
Mac OS Journal/APFS for Mac OS;
NTFS for Windows OS.
It is not recommended to use FAT/eXFAT32 format.
Also please eject the disk before turning off the device.
During the copying process, illegal power off and copy interruption will cause the problem.
pratapj
Post by pratapj »
Thanks for your reply. I used Disk Drill from Clever Files to recover files from the corrupted partition. I was able to retrieve the files which were not backed up. TestDisk is a free alternative to Disk Drill but it is command line only. For me, Disk Drill did the job.
:?: I still don't understand what caused the corruption of two of my disks. They were formatted as Mac OS Journal/APFS for Mac OS and I never pulled them out without safely ejecting them. The DAS is always connected to my Mac mini. :?:
Return to “Thunderbolt 3 Series”
