Looking For Good Thunderbolt 3 Dock
ZhakirSetie
Post by ZhakirSetie »
Hi, I'm currently looking for a good thunderbolt 3 dock and I was wondering if anyone had some good suggestions. The ports I'm looking for are:
At least 3 USB-A ports.
Power delivery.
Gigabit ethernet.
HDMI/Display port that can support up to a 1440p 144hz display.
Thank you!
Re: Looking For Good Thunderbolt 3 Dock
We don't have the right model which meets all your demands. You can take a look at our model D5 Thunderbolt 3 to see if it's acceptable for you https://www.amazon.com/TerraMaster-Thun ... th=1&psc=1
djonesuk
Post by djonesuk »
I don't think TerraMaster make USB docking stations. You might try CalDigit or Monoprice
ZhakirSetie
ZhakirSetie wrote: 02 Jul 2021, 14:33 Hi, I'm currently looking for a good thunderbolt 3 dock and I was wondering if anyone had some good suggestions. The ports I'm looking for are:
At least 3 USB-A ports.showbox speed test
Power delivery.
Gigabit ethernet.
Thank you!
issue gt solved
Charlie_Croker
Post by Charlie_Croker »
I have the Caldigit TS3Plus and the Caldigit Pro Dock (USBC and TB3 depending on device connected to it), both are excellent, however the TS3+ is the better dock, it has DP port or you can use the TB3 out to connect via usb to HDMI as well as DP,
Return to “Thunderbolt 3 Series”
