Permissions qbitorrent and plex
Transmission, qBittorrent, Aria 2 download applications
unixtall
Post by unixtall »
I have to change all permissions for all files i downloaded, it is the only way to plex detects the new file. I have to do chmod 777 file.mkv.
Is it any way to do not manually?
I have 2 folders. One for downloads and another films. Both have the media group user added.
Thanks u.
Re: Permissions qbitorrent and plex
You need to set the media user group read and write permissions of the folder.
unixtall
Post by unixtall »
both folders have these permission.
Uninstall the apps, then go to Control Panel - Shared Folders to edit the names of Plex and qBittorrent. Then reinstall the apps.
unixtall
Post by unixtall »
As you can see in the attachments, the problem is the folder has the correct permission but the files i download not.
Go to Control Panel - Shared Folders, select "Torrents", click "Edit", check "Permissions are inherited to all directories", and then "Apply".
unixtall
Post by unixtall »
The folder has permission, but new files not.
If convenient, you can contact our tech team to check it remotely.
Return to “Download”
