Transmission configurations are lost after restart
Transmission, qBittorrent, Aria 2 download applications
zedidas
Post by zedidas »
I've installed transmission and configured it using the transmission UI.
However, if I try to stop and start transmission in the TNAS Applications window, after restart, the transmission configurations are lost and the default values are shown.
I would expect that stoping and starting transmission through the Applications window should not have any effect on the configurations. How can I make sure that the configurations are not lost?
I already tried several times to uninstall and reinstall transmission, using diferrente configurations but the result is always the same.
Model: F4-210
TOS version: 4.2.17-2110301418
Transmission version: 2.95-200810
Thanks!
Re: Transmission configurations are lost after restart
Thanks for your feedback, we will verify it soon.
zedidas
Post by zedidas »
Do you have an update on this issue?
I have installed new drives into the NAS so that I could have a clean install. Unfortunately, the problem still occurs.
Thank you.
Return to “Download”
