TOS 4.1.18 Transmission app needs to be updated
Transmission, qBittorrent, Aria 2 download applications
Coolant
Post by Coolant »
just wanted to bring this up because i cant use it
Roccia7
Italy
Re: TOS 4.1.18 Transmission app needs to be updated
Post by Roccia7 »
I have no problem with transmission on tos 4.1.18
TNAS F2-220
TOS 5.0.176
Please try to uninstall it and reinstall again.
Spewk
Post by Spewk »
Hi all, new to TOS environment (i've received my F5-221 yesterday)
i have the same problem on TOS 4.1.21: virtualhost/http daemon for port 9091 (transmission web) is looping, even after a reinstallation of the app or by using directly the /transmission/web url
i've tried via SSH to find out which config and http server is using (it's not using the default nginx) but didn't find it out
reboot didn't work either
please have a check about this
Daniele
Please contact us at support(a)terra-master.com, I will ask the engineer here to check for you.
Spewk
Post by Spewk »
Thank you! i've sent it :)
Daniele
Spewk
Post by Spewk »
Alright! just finished a session with your engineers, you have to temporarly use the link in the transmission app by pressing the "Enter" button
9091 port redirect is temporarly not working, but the interface is reachable using 8181 port and the iframe applet ("Enter" button url)
Daniele
