TOS 4.2.06 is released for update!
TOS 4.2.06 Release Notes
This update includes following bug fixes for the previous version, new features and optimized user interface:
1. Optimized the patterns of SSL certificate;
2. Optimized the patterns of fonts at Control Panel;
3. Canceled the feature of uploading documents to TOS desktop;
4. Fixed the issue of Apply button at UPS window;
5. Optimized the searching function at TOS Control Panel;
6. Fixed the issue of password format at password resetting page.
Applicable models:
ARM: F2-210, F4-210
X.86: F2-220, F2-221, F2-420, F2-421, F2-422, F4-220, F4-221, F4-420, F4-421, F4-422, F5-220, F5-221, F5-225, F5-420, F5-421, F5-422, F8-421, F8-422
Important Notes
This update is only suitable for TOS 4.1.27 or above.
This update is not suitable for TOS 4.2.X beta.
SMB, CIFS, AFP, FTP, Telnet, SSH, UPnP and Bonjour services would be enabled (re-enabled) automatically after updating to TOS4.2.06 because of the reset of configuration file.
TOS4.2.06 is compatible only with TNAS Mobile APP 2.4.3 or above.
How to install TOS update?
1. Download the update package:
For X.86: https://dl.terra-master.com/cn/TOS_S2.0 ... 041407.bz2
For ARM: https://dl.terra-master.com/cn/TOS_A1.0 ... 041414.bz2
2. Go to TOS> Control Panel> General Settings> Update & Restore, and click “Manual Update”;
3. Click "Browse" to select the update package;
4. Click "Apply";
5. Clean your browser cache after update.
Issue report:
If you encounter issue during using, please report to TerraMaster official forum “TOS update”.
Miawhite
Re: TOS 4.2.06 is released for update!
Post by Miawhite »
do you have the update for the previous 2 versions?
