After updating to TOS 5 my F2-221 is working! (mostly)
However, after installing Emby and attempt to play any track I get: (No compatible streams are currently available. Please try again later or contact your system administrator for details.) It worked fine with TOS4.
None of my music is playable over UPnP. I can see every folder/track etc.
I'm a novice when it comes to ports and things, I do hope it's not going to be complicated
Emby can see my music but not play any of it
Re: Emby can see my music but not play any of it
Please try to rescan the media library.
Try restarting your device or reinstalling the library
- QuetaDavis
Ensure that you are using the latest version of Emby on your F2-221 device. Check for any available updates and install them if necessary. Sometimes, compatibility issues can be resolved by updating the software.
