Plex doesn't use Hardware Transcode on TOS 5
Discussion about DLNA, multimedia, media server
foucomm
Post by foucomm »
My system is a F4-422 and i install TOS 5. Since i upgrade to TOS 5, my plex will not hardware transcode. As soon as i stream a video at a lower resolution, the system resource will go at almost 100%. But with version TOS 4.2, it will use 10% of the resource. That's why i think that the GPU is not accessible true PLEX. How do i fix this? And yes i do have Plex Pass.
Charlie_Croker
Re: Plex doesn't use Hardware Transcode on TOS 5
Post by Charlie_Croker »
What does Plex show (Settings/Transcoder)? If you have the Plex pass, and a CPU capable on the NAS (The F4-422 should be capable) then you should see hw transcoding.
plex user is not part of the video group (which have the right to use hw transcode)
TM will probably update the module asap
Till then, you can manually install the latest plex tpk
viewtopic.php?f=37&t=3425
or run in ssh:
usermod -aG video "plex"
TM is relly working hard to make TOS5 a success and some things can be forgotten.
That's why we are here as a community.
TMRyan
Post by TMRyan »
{L_BUTTON_AT}foucomm
We have re-listed the app, you can update the app and try hardware transcoding again
foucomm
Post by foucomm »
Update the plex software and all work now. Thanks
Scorp
Post by Scorp »
Device F4-423, TOS 5.0.158, Plex version 1.28.1.6104, user plex added to video group.. But still no hw transcoding. Any ideas?
TMwuu
Post by TMwuu »
Scorp wrote: 25 Aug 2022, 18:23 Device F4-423, TOS 5.0.158, Plex version 1.28.1.6104, user plex added to video group.. But still no hw transcoding. Any ideas?
You need to install Plex online in the App Center and try hardware transcoding again.
Scorp
Post by Scorp »
TMwuu wrote: 25 Aug 2022, 19:42 You need to install Plex online in the App Center and try hardware transcoding again.
No, that didn't help, sorry. =( Anything else maybe?
TMwuu
Post by TMwuu »
Scorp wrote: 25 Aug 2022, 20:13
Can the normal video be played normally?
Scorp
Post by Scorp »
TMwuu wrote: 25 Aug 2022, 21:31 Can the normal video be played normally?
Yep. No problem with this one. Direct stream and software transcoding are working fine.
