Updating to TOS 5.0.126 Kills Plex Server
mightywhitey
Post by mightywhitey »
I've just updated from 5.0.125 to 5.0.126 and it's killed my Plex Server.
It worked fine on 5.0.125, and now I just get 'Operation Failed' when trying to start the server,
Any advice?
Re: Updating to TOS 5.0.126 Kills Plex Server
True, TM need to fix it.
In the meanwhile, you can manually install this .tpk which will also update PLEX to latest version
viewtopic.php?f=37&t=3425
mightywhitey
Thanks for the prompt response!
Annoyingly the new TOS Plex server attached in your reply also doesn't work in 5.0.126.
All worked fine with 5.0.125... but has stopped after the latest update.
Please try the following steps.
1. Login to the SSH terminal.
2. Execute the command below.
adduser -u 6666 -G plex -h /Volume1/Plex -s /bin/false -D plex
3. Go to TOS desktop> App Center to enable the Plex.
@ TMSupport
Not possible to create again the user plex as it was already created during plex installation with id 5555
[xxxx@TNAS-xxxx ~]# adduser -u 6666 -G plex -h /Volume1/Plex -s /bin/false -D plex
adduser: user 'plex' in use
Maybe you can check this option in Plex startup script which prevent plex to start if /Volume1/Plex folder is already existing from previous installation. Maybe is missing the -owner attribute ans is required in the latest firmware ?
[xxxx@TNAS-xxxx ~]# PLEX_HOME=$(ter_share_add -name "Plex")
2022/06/29 17:58:27 {"is_login":false,"code":false,"msg":"user: lookup username root: no such file or directory","data":"","time":0.072580663,"code_num":0,"code_msg":""}
@ mightywhitey
have you manually installed the .tpk file using the menu App Center > Settings and slecting the downloaded tpk ?
Plex should be enabled automatically after manual installation.
Izo
Post by Izo »
Do i have to be developer to use your products, Terramaster?!?
Shame on you!!!
everyday updates means everyday surprises.
When we will receive something working?
I am pissed off. Every update brings some more bugs :o :x
Unable to enable Plex in TOS 5.0.126 has been fixed, please update plex.
ralexlaptop
Post by ralexlaptop »
After updating TOS to 5.0.155-00202, Plex would not start so I uninstalled Plex and reinstalled. The Plex server now starts but some of the TV Show episodes will not display. The Movie and Music files seems to display and play fine.
The Plex version is still 1.27.1.5916 because I'm unable to find a way to update Plex to 1.28.
I saw in this thread that instructions were given to create a Plex user with a home directory of "/Volume1/Plex" so I SSH into the TNAS to check if a Plex user existed.
I did find a Plex user but it was configured as follows:
plex:x:1009:6:TOS App User:/home/plex:/bin/bash
Do you have any recommendations?
ralexlaptop
When I log into my TOS 5.0 NAS, I'm confused by the file permissions assigned.
All the media parent folders are assigned to the initial admin user that I created during the install of TOS 5.0 with the same user as the group with a folder permission of "drwxrwx---". Every folder and file below that parent folder is assigned to the first normal user that I created and is assigned to the allusers group. With file permission of "drwxrwxrwx" for all folders and "-rwxrwxrwx" for all files. I'm assuming that the only reason why the Plex server is able to access any of my media files is because of the Read/Write/Execute permissions to the world on everything. I also don't understand the group file (/etc/group). There is an allusers group but the plex user is not in it and there is a media group but the plex user is not in it either.
ralexlaptop
If I have TOS 5.0 version 5.0.155 installed, why does "/etc/os-release" display the following?
NAME=Terra-Master Tnas
VERSION=3.x
ID=Tnas
VERSION_ID=2018.04.9
PRETTY_NAME="Tnas 2018.04.9"
Return to “Plex”
