Plex continually configuring since updating to TOS 4.2.28
relaxa
Post by relaxa »
After 2 years of Plex working (almost) flawlessly on my F4-210 I have had big problems since updating to 4.2.28
After the update, trying to open Plex would just give me an endless "Configuring..." message and would never open.
Initially I tried replacing the database files with backups which worked for a couple of hours and then went back to the same problem. This time it couldn't be fixed by replacing the database files.
The only solution I found was to uninstall Plex; delete the Plex folder in Home; reinstall Plex and then replace the database files in the new Plex folder. This worked but involved a lot of manual re-jigging to get my database back to where it was, which was a very time-consuming process.
Now, three days later, it has happened again. Same problem, replacing database files does nothing, uninstalling and reinstalling does nothing.
I'm reluctant to delete the Plex folder again as I'm not keen on manually restoring my database again, especially if it's just going to go again in a few days time.
Any ideas please?
TMRyan
Re: Plex continually configuring since updating to TOS 4.2.28
Post by TMRyan »
It is recommended that you no longer use the original database file for replacement but recreate a new database for use.
relaxa
Post by relaxa »
Yeah, problem is I don't want to have to manully reload a 17 library 24000 file database every three days.
There must be a better way.
pupshadow117
Post by pupshadow117 »
Have you tried updating plex to the latest version? The application store doesn't have the latest build so you'll have to download and install it manually. I had the same problem as you but since I updated my plex server is running smooth now. As of typing the latest build is 1.25.5.5492-12f6b8c83.
relaxa
Post by relaxa »
Thanks, just updated now.
All seems ok at the moment, we'll see how things are in a few days.
Return to “Plex”
