Can I can some help, I was having some SMB issues so I updated to the latest version of Terramaster but after my Plex wouldn't start, kept saying configuring and stopping. So I tried to uninstall etc and reinstall etc, no luck. After little while the installer stopped working now all I get with Plex with both the application install and when trying to install manually is Operation Failed. Non of the other topics I've read and troubleshooting or changes to the permissions or Plex folder rename/deletion seems to change this. It also now affected emby as well I get the same issue with that where it just sites there Operation Failed.
I don't even think plex has uninstalled properly from the system. I'm getting no where, I can't find a log or anything related to the application portion of TOS to see what the problem is to fix it. All I was able to find was that my database had corrupted for plex but by then my installer of plex had stopped working won't install it or Emby now and I'm stuck.
Plex Install Issues
Re: Plex Install Issues
HI! Have you try this one for troubleshooting? viewtopic.php?f=83&t=364
- cardajowol
Yes I have looked through that but all that advises is on is Plex not starting or stuck in configuration, it has no information on why application install for Plex or Emby keeps showing "Operation Failed" when trying to install it.
Please follow the instructions in the link below to try it out:
viewtopic.php?f=83&t=815
- cardajowol
Nope, Tried it, even reset TOS box before trying install Plex - Plex was showing "upgrade" not install, clicked it got operation failed, went back to showing "install" and just doing the same again "Operation Failed"
Hi! Can other apps be downloaded successfully? If it also fails, please follow the link to troubleshoot.
- cardajowol
Ya its not a network issue thats working fine. I have been able to download another App. I'm a network engineer for a living I'd know if it was a network issue.
Plus I already advised it gives me the same error when installing manually with the package file of Plex - "Operation Failed" which doesn't require internet connection to install.
