Plex Media Server TPK Package
Gandalf1369
Re: Plex Media Server TPK Package
Post by Gandalf1369 »
Try actually starting the Plex Media Server, then go to the "Settings" menu in PMS and check the server version. Do NOT rely on what the info in the TOS Application store app says - mine still says 1.24 with an update available, but I am actually running 1.25.
F4-220 with 2x8TB, 1x6TB in JBOD (Docker, PiHole, Uptime-Kuma, tnfsd-x64, TOS 5.1.123)
LarryFlynt
Post by LarryFlynt »
PMS says 1.24.1.4931, though I did do the update that says is available before opening it. I can try the install again, but not do the update this time, and see what PMS says.
LarryFlynt
Okay, so now PMS says it's on 1.25.5.5492! If I do the update that the Terramaster desktop is saying is available, it'll put me right back to where I was (1.24.xxxx). Is this a bug with Plex's apk file or with Terramaster?
rightLANE
Post by rightLANE »
LarryFlynt wrote: 18 Feb 2022, 06:29 Okay, so now PMS says it's on 1.25.5.5492! If I do the update that the Terramaster desktop is saying is available, it'll put me right back to where I was (1.24.xxxx). Is this a bug with Plex's apk file or with Terramaster?
As Gandalf1369 says, ignore anything TOS has to say once you start installing TPKs manually. Only rely on the version Plex indicates is installed through the web interface. Same with Emby. I've been installing both Plex and Emby TPKs directly from them for months and TOS always says an update is available. It's a lie.
F2-221 2x 10TB Exos X14
LarryFlynt
Thanks for the suggestions everyone, much appreciated!!
premuto
Post by premuto »
The same thing happened to me, so I will do what you say, I install the tpk, download from plex, install the package manually and that's it, if TOS tells me that there is an update, I ignore it. Thanks for the information.
Daywalker
France
Post by Daywalker »
I successfully installed tpk plex PlexMediaServer-1.25.9.5721-965587f64-x86_64.tpk from plex website but Plex won't running.
Please help me
thanks
F5-422
{L_BUTTON_AT}Daywalker
Please refer to the article for troubleshooting: viewtopic.php?f=83&t=364
Daywalker
France
Post by Daywalker »
Hi
i follow this topic and plex still not running
F5-422
Daywalker wrote: 19 Apr 2022, 17:36 i follow this topic and plex still not running
Please contact our tech team to check it remotely.
Return to “Plex”
