Upgraded router to 802 AX with IPv6
Router reassigned new IP to Terramaster F5-221 and created all kinds of problems. Is there an issue with new 802AX router firewall or IPv6?
Not sure what the issue is but Plex no longer sees the media folders and no option to re-add. there is no "manage" section in PLEX to add/map folders
TNAS shows TNAS Help Failed to Load. Your TNAS is not connected to the internet
The network status shows assigned IP but shows disconnected from Internet
I have uninstalled and reinstalled PLEX 3-4 times hoping to reconfigure a new install but this does not work, system will not prompt for folder locations
Have latest TOS and latest (from Terramaster) Plex Server
If I reset / reinstall TOS will this fix and will I retain media library (data) on the NAS?
Is this normal with a router change?
Issues with Plex
Issues with Plex
- Attachments
- IMG_20210824_2344281.jpg (22.64 KiB) Viewed 2586 times
- IMG_20210824_2344216.jpg (19.32 KiB) Viewed 2586 times
Re: Issues with Plex
Hi!
"Your TNAS is not connected to the internet."
Please check the information about the gateway and DNS.
Go to control panel-> network services-> network-> network interface, and then edit the connected LAN and change the DNS to "8.8.8.8".
After that, you can try to see if plex can be used normally. If the result is the same, you can try to log in to the plex with another account.
Thanks for the prompt reply. I have done as you suggested with no success. I get the same disconnected from the internet messages and Plex still missing the shared media folders on the NAS and no option to add new folders. See Network Interface images.
Note with the old AC router the NAS had IP 192.168.1.115
The new AX IPv6 router seems to keep pushing 192.168.50.2 as a static IP and that is what is assigned to the NAS now.
Hi!
Whether your network is currently connected successfully, if not, please edit the LAN and check "Set as default gateway", and then check the network connection.
