Cannot figure out how to navigate to where files for Plex are to be saved using File Manager. It's gotta be easy but I sure can't figure it out.
Can someone help me?
Accessing Plex Folder Using File Manager
- JeffreyLangBoyd
Re: Accessing Plex Folder Using File Manager
After downloading Plex, TNAS will not automatically generate a plex file. If you cannot find the shared folder that has been added to the plex, you can try the following:
1. Please go to the shared folder in the control panel and set the corresponding permissions of the shared folder
2. Go to Control Panel "Shared Folders" Advanced Settings" to restore, and then you can view Public and Appdata in other volumes in the file management
3. Re-add the shared folder in the plex.
