I'm trying to install the following container (F2-210 under TOS 4.1.24):
https://hub.docker.com/r/bitwardenrs/server
However it can not be found from registry find window.
I checked settings are indeed set to: registry.hub.docker.com, but find results remain empty.
There are some results on "bitwarden", and I can find some other containers, but not that specific one I need...
Thanks for any help.
bitwardenrs server not available
TerraMaster F2-210 under TOS 4.2.43, RAID1, Btrfs, serving Mac, Linux & Windows clients
Re: bitwardenrs server not available
I have tried with the keyword bitwarden here, is the first one the correct container you need?
Here is what I get on my device (registry.hub.docker.com):
I have tried with TOS for 210 model, it's the same as yours. The registry hub is different for Intel and ARM system.
Ok, seems a tagging problem on registry side; definitely not an issue on Docker app.
Thanks.
Thanks.
