Very new user here, to a F5-221. The device seems just fine so far.
I have a problem installing the docker app.
I'm clicking on "Install" and the message displayed in 90% installing...
I tried as a test, to install dropbox, and alo a Text Editor app and they were downloaded just fine.
Can you advise?
Thanks in advance
Docker is not installed. 0% installing..
Re: Docker is not installed. 0% installing..
Hi, I will check with the engineer here and will get back to you later.
In my message I wrote "I'm clicking on "Install" and the message displayed in 90% installing..." by mistake.
It's not 90%.. But 0%. And just stays at 0%, even afte half an hour.
Also same thing is happending for the VirtualBox (beta).
Other Apps that I tried, they were successfully donwloaded and installed at full speed, in a few minutes.
If I may ask something unrelated also, I noticed that there is no package manager e.g. APT-GET, or YUM etc.. when connecting via Telnet.
Is there the possilbility to have it?
Btw it would be very useful if you could add to your list of the apps that you provide, the Home-Assistant, and also advertise it, as you do for Docker. I'm sure it would greatly influence the amount of units that are sold.
e.g. the Docmoz which is a bit similar, is already available in the Apps.
Keep up the good work, everybody!
Thanks.
Thanks.
Well I tried today the docket installation, and was successful. Also the virtual box.
So, consider this resolved.
Today, which is my second day having the NAS, seems to me even better having this web browser environment and being able to control it from whatever can connect to it.
Thx!
Thx!
You are welcome.
