Can't set CPU limit on a container
Discussion about Docker
XFNeo
Post by XFNeo »
docker run -it --rm --cpus 1 nginx
docker: Error response from daemon: NanoCPUs can not be set, as your kernel does not support CPU CFS scheduler or the cgroup is not mounted.
XFNeo
Re: Can't set CPU limit on a container
Post by XFNeo »
Up
TMRyan
Post by TMRyan »
Thank you for your feedback. We already know this problem.
XFNeo
Post by XFNeo »
TMRyan wrote: 18 Jan 2023, 20:19 Thank you for your feedback. We already know this problem.
I'm happy that you know about this) But when will it be fixed?
XFNeo
Post by XFNeo »
{L_BUTTON_AT}TMRyan
Have you fixed this issue?
TMnorah
Post by TMnorah »
You can use the following command to set the maximum use of 1 core CPU
docker container run --name nginx2 -d --cpus 1 nginx
XFNeo
Post by XFNeo »
The same issue:
# docker container run --name nginx2 -d --cpus 1 nginx
See 'docker run --help'.
XFNeo
Post by XFNeo »
After update to 5.1.31 cpu limit in docker works.
Thx
