Docker remove after restart
Discussion about Docker
garry459
Post by garry459 »
I download docker image, start container, all work correctly
But after system restart, i lost all docker images
I can't see any early downloaded images in webUI
And can't see in terminal (connect by ssh and execute command: docker images)
And i lose all running containers (it never restarts after reboot because the image is lost)
I think this is a bug.
I can provide more information (Tell me which command should I execute)
P.S. Device f2-423 TOS 5.0.176
Re: Docker remove after restart
Please go to Control Panel - Shared Folder to check if "DockerData" is located in Volume2 ?
garry459
Post by garry459 »
DockerData located in Volume1
my hardware: HDD 4tb (Volume1) and nvme (system installed)
https://ibb[.]co/HphTdQ4
garry459
Post by garry459 »
litle strange.
After my post, i receive update for docker application (new version 2022-11-23 15:06:44)
I install it, it seems the problem is solved.
After system restart all containers starting successfull.
I thing need some days for check it. But so far it seems that everything is working amazing
