For the installation I'm excuting the following docker-compose.yml
version: "2.1"
services:
calibre-web:
image: linuxserver/calibre-web:latest
container_name: calibre-web
environment:
- PUID=1009
- PGID=1009
- TZ=Europe/Madrid
- DOCKER_MODS=linuxserver/mods:universal-calibre #optional
- OAUTHLIB_RELAX_TOKEN_SCOPE=1 #optional
volumes:
- /Volume1/DockerData/volumes/config:/config
- /Volume1/DockerData/volumes/books:/books
ports:
- 8083:8083
restart: unless-stopped
Things that I noticed in the console:
- Seems that its not able to update itself:
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-security/restricted/binary-amd64/Packages Unable to connect to archive.ubuntu.com:http: [IP: 185.125.190.39 80],
W: Some index files failed to download. They have been ignored, or old ones used instead.,
cont-init: info: /etc/cont-init.d/99-custom-scripts exited 0,
s6-rc: info: service legacy-cont-init successfully started,
s6-rc: info: service init-mods: starting,
s6-rc: info: service init-mods successfully started,
s6-rc: info: service init-mods-package-install: starting,
s6-rc: info: service init-mods-package-install successfully started,
s6-rc: info: service init-mods-end: starting,
s6-rc: info: service init-mods-end successfully started,
s6-rc: info: service init-services: starting,
s6-rc: info: service init-services successfully started,
s6-rc: info: service legacy-services: starting,
services-up: info: copying legacy longrun calibre-web (no readiness notification),
s6-rc: info: service legacy-services successfully started,
s6-rc: info: service 99-ci-service-check: starting,
[ls.io-init] done.,
s6-rc: info: service 99-ci-service-check successfully started,
Could you help me to identify what am I doing wrong? Many thanks
As separate question It would be nice to have the application available for installation natively in TOS
