Error editing container
Discussion about Docker
macmpi
Re: Error editing container
Post by macmpi »
Glad it helped.
With that fix, will we need to re-install the whole Docker app and existing containers, or will applying the fix be simpler.
While at it, thanks to consider the docker app-cleanup on uninstall for btrfs too.
TerraMaster F2-210 under TOS 4.2.43, RAID1, Btrfs, serving Mac, Linux & Windows clients
You just need to update the docker app, that does not affect your app data and containers.
macmpi
Post by macmpi »
My docker app does not automatically start at NAS startup: I need every-time to manually start it.
Even if I check enable box, it will not stay after reboot.
Is it linked to earlier bug or a different one (similar to NFS not starting at boot for instance)?
/etc/init.d/docker restart
cat /var/log/docker.log
Please review log here and assorted warnings.
Thanks for fixing this
I already reported to the tech department, they will look into your case, as soon as I get respond from them, I will let you know. From my point of view,this is issue easy to be resolved.
macmpi
Post by macmpi »
Same problem with June 10th release
Screen Shot 2020-06-14 at 18.35.34.png (14.05 KiB) Viewed 4928 times
in the coming new update, it will be fixed.
macmpi
Post by macmpi »
2 months later, on 4.1.30, still same issue:
Also, my container would still not auto restart after NAS reboot.
sorry for that, we will check with the development team again.
macmpi
Post by macmpi »
TMroy wrote: 25 Aug 2020, 23:46 sorry for that, we will check with the development team again.
2 months later, any news?
Return to “Docker”
