Docker problems agains: Pihole
Discussion about Docker
unixtall
Post by unixtall »
I had the pihole configurated and it was working fine. And one day the container stopped and no more i can do for start it.
I see this error in the log.
::: Testing pihole-FTL DNS: sudo: error in /etc/sudo.conf, line 0 while loading plugin "sudoers_policy"
sudo: /usr/lib/sudo/sudoers.so must be only be writable by owner
sudo: fatal error, unable to load plugins
[cont-init.d] 20-start.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
Always that there is an update, something brokes...
I need help, please tell me what i can do.
unixtall
Re: Docker problems agains: Pihole
Post by unixtall »
I need help. Please!
{L_BUTTON_AT}unixtall
Are you saying something was updated before this appeared?
unixtall
Post by unixtall »
i have just solved this. Uninstalling all dockers containers and creating news.
pkuzila
Post by pkuzila »
I experience the same issue every time my pihole container restarts no matter how it ended. I can get it up and running by doing the following:
su root
chmod 644 /usr/lib/sudo/sudoers.so
chown -R root /usr/lib/sudo
in the pihole container. It takes some doing as the container itself is in a restart loop so you have to catch it at the right time to run the commands. I also noticed that some of my environmental arguments do not get applied such as webpassword.
I also tried removing the container and starting fresh but the issue comes back as soon as it has to restart.
Is there a way to make these permissions persists or does the container need to start in a different way to make this stop happening?
djonesuk
Post by djonesuk »
Appears to be some sort of issue with Pihole:
https://github.com/pi-hole/docker-pi-hole/issues/670
pkuzila
Post by pkuzila »
djonesuk wrote: 03 Aug 2021, 23:51 Appears to be some sort of issue with Pihole:
Wow, not sure how that didn't come up in all my searching, thanks for the link. I'll monitor it over there.
