Hi all,
I am trying to learn how to use dockers and I am beginner so any help is appreciated. I have been trying to use the docker-compose command and all I get is this error message : "/usr/local/bin/docker-compose: /usr/local/bin/python: bad interpreter: No such file or directory". I am not sure if I am doing anything wrong. Below is where I have stored my docker-compose.YAML file
appdata/docker/containers/caddy
Below is the configuration file :
version: "3.7"
services:
caddy:
container_name: "caddy"
image: "caddy:latest"
ports:
- "80:80"
Bwlow is how I access my TNAS:
Maybe I am missing something obvious or I am meant to install extra components. So far I only have docker application installed.
Thanks,
Fareedh
Re: /usr/local/bin/docker-compose: /usr/local/bin/python: bad interpreter: No such file or directory
GUYS!!!
IGNORE ME, I am so dumb. Before running docker-compose command; you need to have python installed on Terramaster. To do this, simply logon to your TOS -> Applications -> Search for python and Install. Once done, docker-compose should work. See my attached image.
