Torrserver Docker
Discussion about Docker
Vihor
Torrserver Docker
Post by Vihor »
Can't install torrserver in Docker. Doesn't find "torrserver" in the repository, although the site does.
https://hub.docker.com/search?q=Torrserver&type=image
https://github.com/YouROK/TorrServer
What can be done, how to install?
F4-210
Vihor
Re: Torrserver Docker
Post by Vihor »
Solved a problem. Installed via the console.
$ docker pull zella/torrserve-linux-arm7
Return to “Docker”
