Hi! I'm new here, I've buyed a F2-421 and I'm triying to install a reverse proxy to have apps running under Docker and use it from external networks, but does not matter what I try, the port does not seems to be open in the NAS, I've triyed Traefik and Nginx proxy manager, with a lot of tutorials, using Docker compose and nothing, I dont know what to do. I've allowed the firewall all connections and when i do "netstat -tunlp | grep 81" the result is this:
tcp 0 0 0.0.0.0:8181 0.0.0.0:* LISTEN 2686/nginx: master
tcp6 0 0 :::81 :::* LISTEN 4771/docker-proxy
tcp6 0 0 :::8181 :::* LISTEN 2686/nginx: master
I assume that the port is listening but I dont know what can be happening.
