How to install Twonky in Docker?
Discussion about Docker
Twonky is suitable for building home multimedia center, allowing multimedia terminals such as TVs, mobile phones, and Pads at home to access the audio and video files in Twonky server.
Applicable Model:
X86 models: F2-220, F2-221, F2-420, F2-421, F4-220, F4-221, F4-420, F4-421, F5-220, F5-221, F5-225, F5-420, F5-421, F5-422, F8-421, F8-422.
ARM models: not supported.
Compatible TOS version:
X86_TOS_4.1.30 and above.
Instructions:
1. Input twonky at Registry under Docker to search and download the suitable image.
2. Check the downloaded image and click Launch.
3. Go to Container - Details- Overview to find the tcp port as the following picture shows:
4.Input TNAS IP address:56867 (such as http://10.18.8.113:56867/ ) to use it.
Return to “Docker”
