How To Install Nextcloud behind a secure reverse proxy (ARM)
Discussion about Docker
StephenM
Re: How To Install Nexccloud behind a secure reverse proxy (ARM)
Post by StephenM »
Just a few last steps now....
vi /mnt/md0/appdata/docker/volumes/nextcloud_nextcloud/_data/config/config.php
Put it in insert mode and navigate around until you find this section:
'trusted_domains' =>
  array (
    0 => '192.168.1.100:8080',
    1 => 'nextcloud.mydomain.com',
    2 => 'UNRAID IP:PORT',
Edit it until it looks like the above.
Find or create this section and edit it to look like this:
'trusted_proxies' =>
  array (
    0 => '192.168.1.0/24',
Add this section at the end:
 'forwarded_for_headers' =>
  array (
    0 => 'X-Forwarded-For',
    1 => 'HTTP_X_FORWARDED_FOR',
To stop your Raid filling up with trash, add this line time:
'trashbin_retention_obligation' => '30, 60',
Once you've done that, try logging to Nextcloud from the outside world.
https://nextcloud.mydomain.com
Finger's crossed you can log in with your admin user.
That's it, you're up and working.
StephenM
Post by StephenM »
As an afterthought I was having some issues with the website not using https on occasion.
Change the proxy host setting under SSL to force secure.
StephenM
Post by StephenM »
Having just upgraded TNAS.....
The ports 80 and 443 are in use by the OS to I did something first time round to overcome this but it seems not to have persisted beyond an upgrade.
A quick mod has fixed this in the docker-compose.yml :
Change to this:
proxy:
    image: 'jc21/nginx-proxy-manager:latest'
    restart: always
    ports:
      # Public HTTP Port:
      - '2080:80'
      # Public HTTPS Port:
      - '2443:443'
      # Admin Web Port:
      - '81:81'
    environment:
Leave the rest of the file as is.
Change your router port forwarding to forward 80 to 2080 on 192.168.1.200 and also 443 to 2443 on 192.168.1.200
StephenM
Post by StephenM »
StephenM wrote: 15 Jan 2021, 03:04 As an afterthought I was having some issues with the website not using https on occasion.
Actually - Doing this causes some strange problems with the desktop app and logging in.
You get egg timers for ever with this setting set.
Odd - don't see why that should be the case.
StephenM
Post by StephenM »
Sorry - I wish I could go back and edit - it would make this much more readable.
Here are some more changes you need in your config.php file.
I had to change one line and add 3
  'overwrite.cli.url' => 'https://nextcloud.mydomain.com',
  'overwriteprotocol' => 'https',
  'overwritehost' => 'nextcloud.mydominc.com',
This probably means that you can force SSL in the proxy rule, but I haven't tested that yet.
yerc1
Post by yerc1 »
{L_BUTTON_AT}StephenM
Fantastic! Thanks for sharing... I have uninstalled the out-of-support Nextcloud app after months of waiting for an update... I am just getting ready to install NextcloudPi on Docker when I saw your post.
F2-221
yerc1
Post by yerc1 »
TM Support, how Stephen detailed the steps within a context, is what I meant in my other post (post #3 of the thread).
F2-221
StephenM
Post by StephenM »
Could a board admin give me the ability to edit my posts until midnight 16th January 2021 GMT please - This needs tidying up and I can't because the posts are not editable by me.
TMS
Post by TMS »
Sorry,I also don’t have permission. You can tell me what needs to be modified, and I can modify it for you (more details on the modification), or you can open another post.
yerc1
Post by yerc1 »
TMS wrote: 15 Jan 2021, 22:35 Sorry,I also don’t have permission. You can tell me what needs to be modified, and I can modify it for you (more details on the modification), or you can open another post.
According to the forum FAQ
What are Administrators?
Administrators are members assigned with the highest level of control over the entire board. These members can control all facets of board operation, including setting permissions, banning users, creating usergroups or moderators, etc.,
Is there someone in your Team with an Administrator access to possibly give StephenM the ability to edit his post?
F2-221
Return to “Docker”
