Sonarr is an RSS subscription tool for Usenet and BitTorrent users. It can monitor the update of multiple movies and episodes you like, and grab, sort and rename them.
Applicable Model:
X86 models: F2-220, F2-221, F2-420, F2-421, F4-220, F4-221, F4-420, F4-421, F5-220, F5-221, F5-225, F5-420, F5-421, F5-422, F8-421, F8-422.
ARM models: F2-210, F4-210.
Compatible TOS version:
X86_TOS_4.1.31 and above.
Instructions:
1. Input sonarr at Registry under Docker to search and download the suitable image.
2. Check the downloaded image and click Launch.
3. Go to Container - Details- Overview to find the tcp port as the following picture shows:
4.Input TNAS IP address:22299 (such as http://10.18.8.98:22299/) to use it.
How to install Sonarr in Docker
