How to install NZBGet in Docker?
Discussion about Docker
NZBGet is a newsgatherer, in which the data format downloaded from newsgroups is nzb file.
Applicable Model:
X86 models: F2-220, F2-221, F2-420, F2-421, F4-220, F4-221, F4-420, F4-421, F5-220, F5-221, F5-225, F5-420, F5-421, F5-422, F8-421, F8-422.
ARM models: F2-210, F4-210.
Compatible TOS version:
TOS4.1.31 and above.
Instructions:
1. Input nzbget at Registry under Docker to search and download the suitable image.
2. Check the downloaded image and click Launch.
3. Go to Container - Details - Overview to find the tcp port as the following picture shows:
4.Input TNAS IP address:33990 (such as http://10.18.8.98:33990/) to use it. The default user name is nzbget, and password tegbzn6789.
Return to “Docker”
