How to install GitLab in Docker?
Discussion about Docker
GitLab is an open source project for warehouse management. It uses Git as a code management tool with Web service built on this basis.
Applicable Model:
X86 models: F2-220, F2-221, F2-420, F2-421, F4-220, F4-221, F4-420, F4-421, F5-220, F5-221, F5-225, F5-420, F5-421, F5-422, F8-421, F8-422.
Not suitable for ARM models.
Compatible TOS version:
All X86 TOS versions.
Instructions:
1. Input Gitlab at Registry under Docker to search and download the suitable image.
2. Check the downloaded image and click Launch.
3. Go to Container - Details - Overview to find the tcp port as the following picture shows:
4.Input TNAS IP address:31915 (such as http://192.168.8.10:31915/) to use it.
Gryphus
Re: How to install GitLab in Docker?
Post by Gryphus »
Dear TMSupport,
thanks for your guideline. I was able to install gitlab via docker in my TOS F2-422.
I also was able to connect to gitlab via the provided HTTP connection and port as shown in your guideline.
I have tried to enable https connection for gitlab in docker but I'm not able to do this. Reason could be my bad knowledge about this kind of topics :)
Can you maybe provide also a guideline how to enable https connection for gitlab in a docker installation (i think it will be helpfull for others too, "hopefully" i'm not the only one with this problem :) )?
Kind regards
