Docker daemon not starting
Discussion about Docker
TMS
Re: Docker daemon not starting
Post by TMS »
You can reinstall the TOS system and restart docker.
pabs
Post by pabs »
Sounds like a great solution? Have a really tested it ? Will it wipe the data ?
Sounds a bit like Have you tried to reboot your router ? :(
TMS
Post by TMS »
pabs wrote: 31 Jan 2021, 19:55 Sounds a bit like Have you tried to reboot your router ?
haven't tried
1. No data will be erased, you can back up important data before reinstalling
2. There may be errors in some system libraries, so you need to reinstall the system
StephenM
Post by StephenM »
I am having the same problem.
It is Docker that isn't starting.
Once I click Docker on the desktop all my containers autostart.
I'll check the status of Docker next time I need to reboot using
service docker status
and I'll bet that it says stopped.
I'm not rebooting anytime soon because when I do I end up having to re-write a config file that gets overwritten at boot time which is a bodge to fix the Time Machine Backup folders size limit - Mentioned in another thread and a solution promised for the last release of TOS which hasn't been delivered.
@TMSupport - Why would any of the libraries have become corrupted - All I've done is done an upgrade suggested by the system.
Has anyone followed the suggestion of re-installing and has it cured the problem?
idiaze
Post by idiaze »
And I have also the same problem. Do any of you have docker initiated on reboot?
StephenM wrote: 31 Jan 2021, 22:22 I am having the same problem.
Vihor
Post by Vihor »
Same problem. Docker does not start itself after reboot, only after clicking on the shortcut. F4-210 (all the newest)
TMRyan
Post by TMRyan »
{L_BUTTON_AT}Vihor
The developers are working on this issue, please wait for the app to update.
Vihor
Post by Vihor »
Thank you. Docker has been updated on 05.17.06 and the problem is gone.
