Mega Sync Setup Issues
CloudSync is a cloud drive synchronization application for fast and secure data synchronization between your TNAS and cloud drives. It is a very practical and efficient one-stop cloud drive disaster recovery solution.
pr0xidian
Post by pr0xidian »
Does anyone else have issues setting up the Mega Sync app? I managed to get 2 jobs setup, but it took a while. I have the F5-221 with the dual core intel and 2GB of ram. I noticed in the task manager while using the "Create Sync Task > Select Cloud Directory" section in the app that it would load endlessly while the ram would fill up, then the web interface would crash and restart. I've upgraded the ram in the unit, and while it no longer fills up and resets the web interface, its still endlessly loading on the mega side. My mega account is the 2TB one and is nearly full, and I know it does client side encryption/decryption. Perhaps it is simply too much for this unit? If anyone knows a fix I'm all ears! Running the current version of the app 2.0.6. Any insight is appreciated! 8-)
Re: Mega Sync Setup Issues
It will take a long time to scan the folder which has abundant of files (especially huge number of small sized files). The endless loading issue may occur in this way. We are working on it now.
piqoqohu
Post by piqoqohu »
The MegaSync setting up on your PC is not that hard.
if you have already sync 2 projects successfully. there shouldn't be any problem
If you need any further assistance, please go through this MegaSync setup guide
Return to “CloudSync”
