Cloudsync doesn't sync?
CloudSync is a cloud drive synchronization application for fast and secure data synchronization between your TNAS and cloud drives. It is a very practical and efficient one-stop cloud drive disaster recovery solution.
MagicPhotoEvents
France
Re: Cloudsync doesn't sync?
Post by MagicPhotoEvents »
I have updated my NAS to TOS 5.0.152 then CloudSync to v. 2.3.4
I had to create again the cloud drive connexion and the synchronisation task, but it has started the job!
One day after, CloudSync was deactivated. But it seems all the content has been synchronised.
Regards,
Olivier
F5-221 TOS 6.0.217, 3 x 4TB RAID5 + 2 x 2TB TRAID
thierrys73
Post by thierrys73 »
hi
it seems run but after severals hours the service dont sync with dropbox
V2.3.4
TWlhq
Post by TWlhq »
{L_BUTTON_AT}MagicPhotoEvents
Did you update the system, reinstall the system, or disable cloudsync before deactivation? This issue will be resolved in the next release.
TWlhq
Post by TWlhq »
{L_BUTTON_AT}thierrys73
Do you operate the task folder? Please wait for CloudSync application update.
MagicPhotoEvents
France
Updated CloudSync to v. 2.3.6
Issue still exists !
Olivier
TMLyy
Post by TMLyy »
What is your synchronization mode, and whether encryption is enabled?
MagicPhotoEvents
France
TMLyy wrote: 14 Aug 2022, 12:24 What is your synchronization mode, and whether encryption is enabled?
Hello, TOS updated to 5.0.157 CloudSync updated to 2.3.7 Use Google Drive CloudSync deactivates itself after some time Olivier
TMnorah
Post by TMnorah »
Hi, we have not been able to reproduce the issue, and we will continue to verify the issue.
MagicPhotoEvents
France
{L_BUTTON_AT}TMnorah
Looking at the log: [at]Level,Time,Category,User,Event Error,2022-08-20 10:00:13,Darktable-Raw-Sync,XXXXXXX,Transmission error Attempt 2/3 succeeded Error,2022-08-20 09:56:43,Darktable-Raw-Sync,XXXXXXX,Transmission error Google drive root 'XXXXXXX: not deleting directories as there were IO errors Error,2022-08-20 09:56:43,Darktable-Raw-Sync,XXXXXXX,Transmission error Google drive root 'XXXXXXX': not deleting files as there were IO errors Error,2022-08-20 09:56:43,Darktable-Raw-Sync,XXXXXXX,"Transmission error Attempt 1/3 failed with 1 errors and: couldn't list directory: googleapi: Error 403: Rate Limit Exceeded, rateLimitExceeded" Error,2022-08-20 09:56:40,Darktable-Raw-Sync,XXXXXXX,"Transmission error XXXXXXX: error reading destination directory: couldn't list directory: googleapi: Error 403: Rate Limit Exceeded, rateLimitExceeded" Error,2022-08-19 20:03:38,Darktable-Raw-Sync,XXXXXXX,"Transmission error Fêtes privées/2022: error reading destination directory: couldn't list directory: googleapi: Error 403: Rate Limit Exceeded, rateLimitExceeded" Error,2022-08-19 19:39:48,Darktable-Raw-Sync,XXXXXXX,Transmission error Attempt 2/3 succeeded Error,2022-08-19 19:38:32,Darktable-Raw-Sync,XXXXXXX,"Transmission error Attempt 1/3 failed with 3 errors and: march failed with 2 error(s): first error: couldn't list directory: googleapi: Error 403: Rate Limit Exceeded, rateLimitExceeded" Error,2022-08-19 19:38:32,Darktable-Raw-Sync,XXXXXXX,Transmission error Google drive root 'XXXXXXX': not deleting directories as there were IO errors Error,2022-08-19 19:38:32,Darktable-Raw-Sync,XXXXXXX,Transmission error Google drive root 'XXXXXXX': not deleting files as there were IO errors Error,2022-08-19 19:37:37,Darktable-Raw-Sync,XXXXXXX,"Transmission error XXXXXXX: error reading destination directory: couldn't list directory: googleapi: Error 403: Rate Limit Exceeded, rateLimitExceeded" Error,2022-08-19 19:36:46,Darktable-Raw-Sync,XXXXXXX,"Transmission error XXXXXXX: error reading destination directory: couldn't list directory: googleapi: Error 403: Rate Limit Exceeded, rateLimitExceeded" Error,2022-08-19 17:41:34,Darktable-Raw-Sync,XXXXXXX,Transmission error Attempt 3/3 succeeded Error,2022-08-19 17:39:27,Darktable-Raw-Sync,XXXXXXX,"Transmission error Attempt 2/3 failed with 1 errors and: couldn't list directory: googleapi: Error 403: Rate Limit Exceeded, rateLimitExceeded" Error,2022-08-19 17:39:27,Darktable-Raw-Sync,XXXXXXX,Transmission error Google drive root 'XXXXXXX': not deleting files as there were IO errors Error,2022-08-19 17:39:27,Darktable-Raw-Sync,XXXXXXX,Transmission error Google drive root 'XXXXXXX': not deleting directories as there were IO errors Error,2022-08-19 17:38:49,Darktable-Raw-Sync,XXXXXXX,"Transmission error XXXXXXX: error reading destination directory: couldn't list directory: googleapi: Error 403: Rate Limit Exceeded, rateLimitExceeded" Error,2022-08-19 17:35:33,Darktable-Raw-Sync,XXXXXXX,"Transmission error Attempt 1/3 failed with 1 errors and: couldn't list directory: googleapi: Error 403: Rate Limit Exceeded, rateLimitExceeded" Error,2022-08-19 17:35:33,Darktable-Raw-Sync,XXXXXXX,Transmission error Google drive root 'XXXXXXX': not deleting files as there were IO errors Error,2022-08-19 17:35:33,Darktable-Raw-Sync,XXXXXXX,Transmission error Google drive root 'XXXXXXX': not deleting directories as there were IO errors Error,2022-08-19 17:33:30,Darktable-Raw-Sync,XXXXXXX,"Transmission error XXXXXXX: error reading destination directory: couldn't list directory: googleapi: Error 403: Rate Limit Exceeded, rateLimitExceeded" Error,2022-08-19 12:26:23,Darktable-Raw-Sync,XXXXXXX,Transmission error Attempt 2/3 succeeded Error,2022-08-19 12:25:19,Darktable-Raw-Sync,XXXXXXX,Transmission error Google drive root 'XXXXXXX': not deleting directories as there were IO errors Error,2022-08-19 12:25:19,Darktable-Raw-Sync,XXXXXXX,Transmission error Google drive root 'XXXXXXX': not deleting files as there were IO errors Error,2022-08-19 12:25:19,Darktable-Raw-Sync,XXXXXXX,"Transmission error Attempt 1/3 failed with 1 errors and: couldn't list directory: googleapi: Error 403: Rate Limit Exceeded, rateLimitExceeded" Error,2022-08-19 12:24:26,Darktable-Raw-Sync,XXXXXXX,"Transmission error XXXXXXX: error reading destination directory: couldn't list directory: googleapi: Error 403: Rate Limit Exceeded, rateLimitExceeded"[/at] Does CloudSync manage Google Drive transmission errors ?
MagicPhotoEvents
France
Last news about the issue...
CloudSync version 2.3.7
TOS version 5.0.160
Google Drive synchronisation errors still occur, but files are backuped.
CouldSync seems to be stable.
I've contacted Google Drive support, an "expert" has been told about the problem, but I don't believe they'll fix it.
Olivier
Return to “CloudSync”
