I recently purchased the F2-210 because it was compatible with OneDrive. Set up has been easy and the system is working well except that OneDrive isn't syncing correctly. Any changes made on documents in OneDrive sync to the F2-210, however any changes made on documents held in the F2-210 do not sync back to Onedrive. Instead the file gets overridden by the old version in OneDrive. I've checked the settings to be sure it is set as "Bidirectional" and it is. Is there something i should be doing?
OneDrive Sync
Re: OneDrive Sync
Hi, after receiving your feedback, we will verify if this problem exists
