Yes only this month
And I think it does too many class c lookups
I found a message on backblaze about synology nas causing problems it seems the terranas is calling the Class C transaction--B2 list_filenames too often
https://help.backblaze.com/hc/en-us/art ... -Synology-
how does backblaze work ?
Re: how does backblaze work ?
F2-220 WITH 2 x WD RED 2TB RUNNING 4.2.17
Hi!
Backblaze APP has not been updated recently. In theory, the monthly bill should not change. It may be caused by being stuck when synchronizing files and then searching in a loop.
I have removed my docker config folder as this had some files that were updating multiple times a minute and it seems like it’s normal again
Lidarr and headphones for instance have a db that seems to cause backblaze app to go crazy
