Source Filesystem
Discussion about USB Copy.
Napalmweasel
Source Filesystem
Post by Napalmweasel » 23 Apr 2020, 23:27
In the previous TOS version's USB backup function, I had to change my filesystem to BTRFS. Is that still necessary for the new USB Copy application, or can I reformat to something else?
Customer Service
Re: Source Filesystem
Post by TMSupport » 24 Apr 2020, 15:16
Are you sure? There should be no limitation about file system format when using USB Copy. The supported format for TOS file system is BTRFS and EXT4. Both should be ok for using USB Copy.
