Cannot Update or Uninstall USB Copy
Discussion about USB Copy.
werzaque
Post by werzaque »
Dear Community,
I have a problem with USB Copy. Since TOS was updated, I want to update USB Copy as well, but it will not let me. It also will not let me uninstall it. I suspect the application has become corrupted, but is there any way to force an uninstall so that I can do a fresh clean install of USB copy? Many thanks.
Frank
Stuck in this state. The word after the percent sign flashes between "Installing" and "Updating" continuously.
werzaque
Re: Cannot Update or Uninstall USB Copy
Post by werzaque »
TOS version is 4.2.09-210251735 by the way
Is it the only issue with USB Copy or all the apps?
werzaque
Post by werzaque »
Clam Antivirus works just fine, and I just tried to install "Web Server", which seems to be working as far as I can tell. Those are the only apps that I have installed at the moment.
KR,
Frank
Please SSH access your TNAS and logged in as root (the password is the login password of admin) and run the cmd line below:
1. rm /tmp/wget-usbcopy
2. rm /tmp/scripts_run/get.usbcopy
The refresh the page to reinstall USB Copy.
werzaque
Post by werzaque »
Dear Support,
Sorry for the belated reply. I am getting the following error :| . Please advise.
Welcome to Tnas!
[admin@TERAKO ~]$ rm /tmp/wget-usbcopy
rm: remove write-protected regular file '/tmp/wget-usbcopy'? yes
rm: cannot remove '/tmp/wget-usbcopy': Operation not permitted
[admin@TERAKO ~]$
Please SSH login as root to run the cmd lines, the login password is the same with admin's TOS login password.
werzaque
Post by werzaque »
Many thanks! And sincere apologies for the lack of reading comprehension on my part :oops:
Issue seems to be solved now.
