[ Homarr ] A simple, yet powerful dashboard for your server
About: https://homarr.dev/
Category:
Applicable TOS4: 4.1.27 or later versions - on request
Applicable TOS5: 5.1.37 or later versions
App download: https://tmnascommunity.eu/download/homarr
Required packages:
NodeJS
TOS4: http(s)://yournasip:port/modules/Homarr/www
TOS5: click on Support & Help from app description inside the App Center
About
Simplify the management of your server with Homarr - a sleek, modern dashboard that puts all of your apps and services at your fingertips. With Homarr, you can access and control everything in one convenient location. Homarr seamlessly integrates with the apps you've added, providing you with valuable information and giving you complete control. Installation is a breeze, and Homarr supports a wide range of deployment methods.
ostaporomo
Finland
Re: [ Homarr ] A simple, yet powerful dashboard for your server
Post by ostaporomo »
Hello! The application shortcut image is not displayed on the desktop and in the application store
TNAS F2-223
TOS 5.1.79-00214
2x RAM Samsung 16GB DDR4 2133 MHZ
2x HDD Segate IronWolf ST4000VN008 4TB [RAID1]
DAS D4-300
2x HDD Seagate SkyHawk ST3000VX010  [RAID1]
2x HDD Toshiba DT01 DT01ACA300-3TB
dimitsu91
Israel
Post by dimitsu91 »
Hey there, will there be a support for TOS6, as it seems that when i try to access the app i get the following error:
im logged in as and super-user
Yes it will be
