[ PydioCells ] Self-hosted Document Sharing, Management and Collaboration
About: https://pydio.com/en
Category:
Applicable TOS4: 4.1.27 or later versions - on request
Applicable TOS5: 5.1.37 or later versions
App download: https://tmnascommunity.eu/download/PydioCells
TOS4: http(s)://yournasip:port/modules/PydioCells/www
TOS5: click on Support & Help from app description inside the App Center
About:
Does your organization have complex compliance and security issues? Are SaaS solutions out of the question for you? Pydio Cells gives you full control of your document sharing environment – combining fast performance, huge file transfer sizes, granular security, and advanced workflow automations in an easy-to-set-up and easy-to-support self-hosted platform.
