[ croc ] (CLI) Easily and securely transfer stuff from one computer to another
About: https://github.com/schollz/croc
Category:
Applicable TOS4: 4.1.27 or later versions - on request
Applicable TOS5: 5.1.37 or later versions
App download: https://tmnascommunity.eu/download/croc
TOS4: http(s)://yournasip:port/modules/croc/www
TOS5: click on Support & Help from app description inside the App Center
About
croc is a tool that allows any two computers to simply and securely transfer files and folders. AFAIK, croc is the only CLI file-transfer tool that does all of the following:
allows any two computers to transfer data (using a relay)
provides end-to-end encryption (using PAKE)
enables easy cross-platform transfers (Windows, Linux, Mac)
allows multiple file transfers
allows resuming transfers that are interrupted
local server or port-forwarding not needed
ipv6-first with ipv4 fallback
can use proxy, like tor
