[ Htop ] CLI interactive process viewer
About: https://github.com/htop-dev/htop
Category:
Applicable TOS5: 5.1.33 or later versions
Applicable TOS7: 7.0.0420 or later versions
App download: https://tmnascommunity.eu/download/htop
TOS4: http(s)://yournasip:port/modules/pgAdminOKM/www
TOS5: click on Support & Help from app description inside the App Center
Connect with SSH and run
htop
About
htop is a cross-platform interactive process viewer.
htop allows scrolling the list of processes vertically and horizontally to see their full command lines and related information like memory and CPU consumption. Also system wide information, like load average or swap usage, is shown.
The information displayed is configurable through a graphical setup and can be sorted and filtered interactively.
Tasks related to processes (e.g. killing and renicing) can be done without entering their PIDs.
Running htop requires ncurses libraries, typically named libncurses(w).
lilduke316
Re: [ Htop ] CLI interactive process viewer
Post by lilduke316 »
Does this still work for tos6? Current version 6.0.673. on f2-423. I see it says version 5 or later on the community apps, but wasn't sure if that also means version 6 also.
Not ready for TOS6 but will be updated soon
lilduke316
That's awesome thanks for the heads up!
CodeTheFuture
Australia
Post by CodeTheFuture »
Thanks for the package outkastm.
Since htop version 3.4.1 and later you can use htop to do more such as view GPU utilization.
Any chance of getting this package updated to the latest htop version please?
Sure, will be done asap
latest version is available for download
