[ SolidInvoice ] Invoicing application
About: https://solidinvoice.co
Category:
Applicable TOS5: 5.1.24 or later versions
App download: https://tmnascommunity.eu/download/SolidInvoice
Required packages:
apache24
PHP81_okm
MariaDB
TOS4: http(s)://yournasip:port/modules/pgAdminOKM/www
TOS5: click on Support & Help from app description inside the App Center
About:
SolidInvoice is a simple open source invoicing application aimed to help small businesses and freelancers manage their day-to-day billing.
It's a feature rich elegant online application, available as a cloud solution to ensure that you can always get paid on time.
Client Management
Capture all your client information in an easy to use client management interface.
Quoting and Estimates
Send quotes to your clients and convert quotes into invoices.
Send Invoices
Send invoices and keep balances up to date to know exactly how much income you should receive.
Online Payments
Receive online payments through a number of different payment gateways.
Recurring Invoices
Send recurring invoices on a flexible schedule that matches your business.
Multiple Currencies
Multiple currency support means you can bill your client in any currency that they prefer.
Powerful API
A powerful and flexible API makes integration into any other service so much easier.
Scottnorwo
Re: [ SolidInvoice ] Invoicing application
Post by Scottnorwo »
Tos 6 updates????
Will add it on to do
