[ PostgreSQL_okm ] Most Advanced Open Source Relational Database
About: https://www.postgresql.org
Category:
Applicable TOS4: 4.1.27 or later versions - on request
Applicable TOS5: 5.1.12 or later versions
App download: https://tmnascommunity.eu/download/postgresql_okm/
Required packages:
pgAdminOKM > 6.17.0.0
TOS4: http(s)://yournasip:port/modules/pgAdminOKM/www
TOS5: click on Support & Help from app description inside the App Center
Follow this guide How to create an user and database in PostgreSQL to create specific user and database required for specific apps
About:
PostgreSQL is a powerful, open source object-relational database system with over 35 years of active development that has earned it a strong reputation for reliability, feature robustness, and performance.
There is a wealth of information to be found describing how to use PostgreSQL through the official documentation. The open source community community provides many helpful places to become familiar with PostgreSQL, discover how it works, and find career opportunities. Learm more on how to engage with the community.
mmedic
Re: [ PostgreSQL_okm ] Most Advanced Open Source Relational Database
Post by mmedic »
Hi! Thank you for the application. Unfortunately, i got an error on activation of the package (TOS 6.0.610). The packages also installed: pgAdminOKM v6.17.0.0, apache24 v2.4.54.1, Python310 v3.10.5.0 Would you be so kind to advice what I can check to load the pg? It was uninstalled and reinstalled already with no positive effect. TOS SPC is turned off.
F4-424, actual TOS6
This app is not ready yet for TOS6
mmedic
Post by mmedic »
Okay! Thank you for the reply.
Will wait for the updates. I was asking for the support as https://tmnascommunity.eu/download/postgresql_okm/ contain a note that it is compatible with TOS6 (Applicable TOS6: 6.0.420 or later versions).
F4-424, actual TOS6
SeppMaier
Germany
Post by SeppMaier »
Hello, when will PostgreSQL be available for TOS7 ?
I'm using TOS 7.0.1140 and I was NOT warned before updating!
Will be upfated adap to be fully compatible with TaoS7
