Organizr
bradl822
Organizr
Post by bradl822 »
I have been trying to get organizr working on Docker however all the containers for organizr use listening port 80 which is used by TOS.
How easy... Or difficult is it to package to work with TOS?
I have started with the documentation and it looks fairly involved.
Re: Organizr
Can be done for x86 platform
bradl822
Re: Organizr
Post by bradl822 »
X86 is what I am using, are you referring to can be done in Docker. Or as a tos package? Any tips in the right direction?
Re: Organizr
Can be done as TOS package
