[ InfluxCLI ] CLI to interact with and manage your InfluxDB instance
About : https://docs.influxdata.com/influxdb/v2 ... i/?t=Linux
Category: Tools
Applicable models: x.64 series, ARMv8 series
Applicable TOS5: 5.0.170 or later versions
App download: https://tmnascommunity.eu/download/influxcli/
http(s)://yournasip:port/modules/InfluxCLI/www
About:
Provide required authentication credentials
To avoid having to pass your InfluxDB host, API token, and organization with each command, store them in an influx CLI configuration (config). influx commands that require these credentials automatically retrieve these credentials from the active config.
Use the influx config create command to create an influx CLI config and set it as active:
influx config create --config-name <config-name> \
  --host-url http://localhost:8086 \
  --org <your-org> \
  --token <your-auth-token> \
  --active
Re: [ InfluxCLI ] CLI to interact with and manage your InfluxDB instance
added TOS5 version
